Dyna S ignition removed from my Z900. What you get is as per pictures. Fully functioning and only removed because my 1260 motor runs such a high compression that it needs a custom map that one can only do with Dyna 2000. I dont have the instructions but i think they are a download from the Dynajet web site or i can copy the instructions from my Katana which has same system and i suspect exactly the same fitting instructions. Price is £95 including post to UK mainland, fully insured via Parcelforce.
Dyna S ignition
martinz1000r
Dyna S ignition
