Gpz1100b1 Grab rail
Gpz1100b1 Grab rail
My grab rail has a long stem on the right hand side and a short stem on the left hand side. The right hand side mates perfectly to the frame mount. The left hand side does not reach the frame mount. Looks like a space of about 15mm...approximately. Does some sort of spacer live here normally?
Re: Gpz1100b1 Grab rail
The helmet lock has a tubular spacer fixed to it of that approximate size.
Thanks Al, I’ll try and find some pictures of a seat lock and how it’s fitted.
- sockpuppet
Hi Scott
As AL says the grab rail mounting bolt on the left side passes through the seat catch/ helmet lock .
Mick
Mick
https://www.cmsnl.com/kawasaki-kz1000j1 ... 62046.html
27016A Shows the seat catch / helmet lock with the spacer attached.
You could just make a tubular spacer if you dont need the catch.
Thanks, appreciated.
27016 5069 seems to be unavailable.....any ideas where to get one?
These are quite hard to find unfortunately... 1000r, 1100R and some 550s use the same lock
Thanks, i'll look forward to the search
Fairly sure this is one.
https://www.ebay.co.uk/itm/83-Kawasaki- ... rk:35:pf:0
NOT THIS ONE SORRY
https://www.ebay.co.uk/itm/Helmet-Lock- ... rk:38:pf:0
NOT THIS ONE SORRY
Works out about £50 from the states, maybe worth a punt. I think it says that it has no keys. Can I replace the barrel for one with a key?
Second one above looks cheaper and you can get a key cut using the stamped number on it.
EDIT SECOND ONE (GPZ 550) IS A RED HERRING SORRY.
https://www.ebay.co.uk/itm/Seat-Lock-Me ... :rk:1:pf:0
Looks like Tomforde does a no key replacement part might be B2 only!!!!!!!
Ok, at least I know I can fall back on the Tomforde one if necessary.
Scott I must have it here! let me look before you spend out
Users browsing this forum: No registered users and 110 guests
