I lifted the dust cover on the Z at the weekend and was disheartened to find a smattering of white oxide on the cases. May be I only did a second rate job if cleaning it back in September but I started thinking – does anyone use one of these: -
https://www.vac-bag.co.uk/motorcycle-vac-bags.html
Are they practical? Or is this the way to go: -
https://www.mandp.co.uk/zerust-motorcycle-protection-storage-bag.html
Vac-Bags
- wheelysteve
Re: Vac-Bags
I have used the vac bag. It's a bit of a faff to get the bike in (mind you it was in a tight space). The bags are pretty robust and they do work. The drying agent is in a sealed bag and this lasts for months if you seal the big bag properly. Along with the heavy duty tie pull, I put a couple more on it. Bike was exactly as I put it in there when I took it out months later.
Steve
Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
- warren3200gt
Re: Vac-Bags
If your space is vaguely air tight or can be then get a dehumifier instead and keep everything in the garage rust free, not just whats in the bag.
Re: Vac-Bags
coat in acf50.
I also use a dehumidifier in a double garage and don't have a problem.
