Did Kawasaki use non setting gasket
Gavin
#1 PostAuthor: Gavin » Tue Jan 29, 2019 3:58 pm
The reason I ask is, I am stripping the MK2 engine and originally I was convinced that it had never been apart before, however I have just removed the oil pump and there was only 1 knock pin instead of 2 and you can see the crankcase half’s have had non setting gasket on them, I was sure that when I stripped my z1100 shaft many years ago that it wasn’t used on its crankcases,
Z1000 MK2
Z1300 DFI
RALPHARAMA
Re: Did Kawasaki use non setting gasket
#2 PostAuthor: RALPHARAMA » Tue Jan 29, 2019 4:35 pm
I think they used Kawabond, which is very similar to 3 bond.
I personally swear by Wellseal.
I hate to think KHI would have missed out a knock pin :shock:
Ralph Ferrand
8 Valve Mark
#3 PostAuthor: 8 Valve Mark » Tue Jan 29, 2019 4:50 pm
semi-permanent liquid gasket on the bottom c/case gavin. it looks like there's a pin missing so the pump has probably been off.
#4 PostAuthor: Pigford » Tue Jan 29, 2019 6:14 pm
Gavin wrote:The reason I ask is, I am stripping the MK2 engine and originally I was convinced that it had never been apart before, however I have just removed the oil pump and there was only 1 knock pin instead of 2 and you can see the crankcase half’s have had non setting gasket on them, I was sure that when I stripped my z1100 shaft many years ago that it wasn’t used on its crankcases,
You can remove the oil pump without splitting the cases... so not 100% proof?
Users browsing this forum: No registered users and 110 guests
