Wanted 26mm Mikuni carbs
dynodave
#1 PostAuthor: dynodave » Sat Feb 02, 2019 3:48 pm
Wanted good set of ready to go standard 26mm Mikuni carbs. Must be in full working order.
needaz1100r
Re: Wanted 26mm Mikuni carbs
#2 PostAuthor: needaz1100r » Sat Feb 02, 2019 5:20 pm
dynodave wrote:Wanted good set of ready to go standard 26mm Mikuni carbs. Must be in full working order.
I've got a couple of sets. I'll PM you later after I've fed my monster, I mean daughter!
Cheers,
Mark.
#3 PostAuthor: kev edwards » Sat Feb 02, 2019 7:45 pm
I have a set if you have no joy, 26mm A2 carbs sonic cleaned, bench set, 102mains, 15 pilots, 5cn7-3 needles, home made brass tees between carbs with new viton o'rings, float levels set WET, and a spare set of 112.5 mains.
dynodave
#4 PostAuthor: dynodave » Sun Feb 03, 2019 9:32 am
Cheers Kev
