HOW TO FIT ENGINE BARS TO A ZED
london calling
#1 PostAuthor: london calling » Wed Apr 02, 2008 6:19 pm
Any sensible suggestions,as I'm asking on behalf of someone else.
Jack
#2 PostAuthor: Rich » Wed Apr 02, 2008 6:25 pm
That rules my answer out !
#3 PostAuthor: Pigford » Wed Apr 02, 2008 6:42 pm
Jack AVON- Calling,
The only 2 problems:
The engine bolts may not be long enough :shock:
They make the bike look naff :??
mikey
#4 PostAuthor: mikey » Wed Apr 02, 2008 7:15 pm
Got em on my Z1000 jack and they were on there when i got it
and as far as im aware all the engine bolts are standard size
bunnysZ
Granny Magnet
#5 PostAuthor: bunnysZ » Wed Apr 02, 2008 7:43 pm
i think the the small casing huggeing ones look ok, but as piford says , long engine mounting bolt is not long enough for them , side tear drop nut and bolts are a bugger to get back on, and if you have the original exhaust on near impossible.
patience patience luck and more patience needed.
but if you drop the bike worth it
KeithZ1R
#6 PostAuthor: KeithZ1R » Wed Apr 02, 2008 9:47 pm
Got em on me Z1R but i had to get some round bar cut it to length and thread the ends looks ok and the've been on for 18 years
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Ed Z1-R
#7 PostAuthor: Ed Z1-R » Wed Apr 02, 2008 9:56 pm
I got Krash barz on the Z1-R.
Briefly;I measured the overall length of bolt +size of washers and nuts to be used,add thickness of K bars, about 4ish mm so there is at least a couple of turns of thread.
Got a length of bar for the machinist to cut threads either end.
Looks pukka assembled :up
Steve S
#8 PostAuthor: Steve S » Thu Apr 03, 2008 11:37 am
Ive got a double threaded (ie for 2 nuts)long front mounting bolt from my Z1A,which I have now replaced with a standard one, must have had crashbars on it at some time,Dave at Zed power said that was a common way to fit in the 'old' days. :)
KeithZ1R
#9 PostAuthor: KeithZ1R » Thu Apr 03, 2008 12:48 pm
top tip drill the tear drop nut on the bottom edge 3mm and sit em on an electricians srewdriver before trying to locate them saves all that figglin about and cursin when the thread wont engage
Keith
:bop :gom
mistaken.
