LH Front Brake caliper and bracket Z1000 A1
GuyHughes
#1 PostAuthor: GuyHughes » Mon Feb 18, 2019 12:08 pm
I'm looking for a LH, (as you sit on the bike), Front Brake caliper and bracket for a KZ1000 A1 1977 part number 43041-029. Would like it to be as complete as possible and as a good condition as possible but all items considered. UK Preferred but will again consider any location. See image below.
Guy
8 Valve Mark
Re: LH Front Brake caliper and bracket Z1000 A1
#2 PostAuthor: 8 Valve Mark » Mon Feb 18, 2019 2:02 pm
ive got a lhs bracket, the caliper from a 650,900 are the same as the a1, to widen your options.
GuyHughes
#3 PostAuthor: GuyHughes » Mon Feb 18, 2019 5:22 pm
8 Valve Mark wrote:ive got a lhs bracket, the caliper from a 650,900 are the same as the a1, to widen your options.
Excellent then that is a start thanks.
Guy
Gonzo
#4 PostAuthor: Gonzo » Mon Feb 18, 2019 6:13 pm
I have a left hand bracket / caliper sitting on the shelf but it needs a paint job.
It came off my Z1000A2 when I had the brakes revamped but was told it was from Z900A4 or Z650 as the fitting for the brake pipe is slightly different on the 'thou'. I replaced it with the correct part.
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
GuyHughes
#5 PostAuthor: GuyHughes » Tue Feb 19, 2019 11:46 am
Gonzo wrote:I have a left hand bracket / caliper sitting on the shelf but it needs a paint job.
I have sent you a private message.
Guy
#6 PostAuthor: ADRIAN H » Tue Feb 19, 2019 8:39 pm
From Partzilla
Kawasaki - 43041-029 FRONT CALIPER fits the following models and components:
Kawasaki Motorcycle 1979 Z1000 A3A FRONT BRAKE ('77-'78 A1/A2/A2A)
Kawasaki Motorcycle 1979 Z1000-A3 FRONT BRAKE ('77-'78 A1/A2/A2A)
Kawasaki Motorcycle 1978 Z1000 A2 FRONT BRAKE ('77-'78 A1/A2/A2A)
Kawasaki Motorcycle 1980 Z1000-A4 FRONT BRAKE ('77-'78 A1/A2/A2A)
Kawasaki Motorcycle 1978 Z1000-A2A FRONT BRAKE ('77-'78 A1/A2/A2A)
Kawasaki Motorcycle 1977 Z1000-A1 FRONT BRAKE ('77-'78 A1/A2/A2A)
z1 Dave
#7 PostAuthor: z1 Dave » Fri Mar 08, 2019 10:46 am
Are you still looking for one? I have one for sale
David
GuyHughes
#8 PostAuthor: GuyHughes » Mon Mar 11, 2019 9:48 am
z1 Dave wrote:Are you still looking for one? I have one for sale
David
I have two now, but would like to see what condition it is in please.
Guy
