Hi anyone got a 22mm id starter clutch thrust washer(the 2mm thick one with four grooves on one side) and any rubber damper spacers to fit 900 engine that they are willing to sell.
Thanks David
Wanted starter clutch thrust washer and rubber damper
Re: Wanted starter clutch thrust washer and rubber damper
Hi David
I think you can order the copper washer at Z-power.
http://www.z-power.co.uk/z900a4-kz900b1 ... 0010001100
The rubber damper could become a problem.
The parts numbers are: 92075192, 92075193 and 92075194.
Keep in mind that the rubber damper is available in 3 different measurements. The thickness is marked on the damper with stars (very little ones, use a magnifing glass to see them) There are 1, 2 or 3 stars. These represent the thickness, one star for the thinnest, three stars for the thickest.
If you have the old damper figure out which one you need. If not, install the rotor with the starter cluth and measure the gap to know which one you need for your engine.
Good luck
Good luck
Thanks Philippe
I have seen the thrust washer at Z-power and its the one that goes between the starter clutch and the rotor I need the one that goes between the starter clutch and the crankcases part number 92026-091.
Re the rubber damper just haven't got around to buying some plasticine to measure.
Thanks David
Thanks David
I think the damper rubber is on ebay.com new (eBay usa) you may well get clobbered by customs
Z900a4, BMW 1200GS, H-D 1200, KTBFFH
Yes it's on there, type kz900 starter in search and you will find it...
Bad news though it's $75 with shipping.
