Early z1 Frame wanted
I have two early Z1 engines one in the 00400s the other in the 00700s does anyone have an early frame they would sell? tia.
neilbarrett
- ZedHead
Re: Early z1 Frame wanted
try z1 historical on fb ,id hav thought you hav more chance of getting an early frame from the states ,if some one knows you've a motor for one theyre gunna charge you top wack ,wonder how the motors ended up over here minus the frames ?
I have asked on most of the FB groups with no luck.neilbarrett wrote:try z1 historical on fb ,id hav thought you hav more chance of getting an early frame from the states ,if some one knows you've a motor for one theyre gunna charge you top wack ,wonder how the motors ended up over here minus the frames ?
