just wondered if anyone else has had a problem with this bit? I can probably move it back upwards with a bit of gentle pressure Hello Guest User,
z power center stand
Anyone ever had a problem with the leg arm of the z power main stand bending on operation? I bought a brand new one a few years ago never used it, and sold it to my mate who spent a few hours fitting it to his A4 hoho, if you must have the four pipes
expect the extra work, yes he's bent it so its lower than the LH foot of the mainstand so a bit wobbly
just wondered if anyone else has had a problem with this bit? I can probably move it back upwards with a bit of gentle pressure More Smiles Per Mile
Re: z power center stand
mine fitted perfectly 1st time and has been great ....I also have 4 pipes
crossthread
- Regular Poster
Did I mis-read that? What's bent , the stand or the exhaust ? A stand that that you can bend back with " gentle pressure " sounds a bit dodgy !!!
Don't know if it's the same with Zeds but Seem to recall this coming up a while ago with Pattern Triple stands. Seems the metal is much thinner and easier to bend.
I got one last year no problems just a strong as the original.
I have one on my z1000 a1 and its spot on
Having seen the stand in question, I'd say it's a repro - I have never seen an OEM stand bend and crease. I would suspect that if you bend it back it will go again.
