28mm z1r carb
DDZ900
28mm z1r carb
#1 PostAuthor: DDZ900 » Thu Apr 11, 2019 8:18 pm
Any 1 on here got a 28mm z1r r/h carb for sale ! or would buy full set . pm me :roll:
8 Valve Mark
Re: 28mm z1r carb
#2 PostAuthor: 8 Valve Mark » Thu Apr 11, 2019 10:26 pm
it's probably easier to find a set duane, (unfortunately) than if you try to find one! :sad what's your dilemma?? m
DDZ900
Re: 28mm z1r carb
#3 PostAuthor: DDZ900 » Fri Apr 12, 2019 6:32 am
1 of the carbs has been bodged i think ! Nigel from Aire valley classics is rebuilding them !
gpjes
Re: 28mm z1r carb
#4 PostAuthor: gpjes » Fri Apr 12, 2019 8:13 am
ST ones good upgrade
More Smiles Per Mile
Re: 28mm z1r carb
#5 PostAuthor: Ultim8pc » Fri Apr 12, 2019 9:37 am
DDZ900 wrote:1 of the carbs has been bodged i think ! Nigel from Aire valley classics is rebuilding them !
I think more correctly it should be 'trying to salvage them'.
DDZs set are in very poor shape. All air screws, throttle slides and float pins seized solid. I have managed to un-seize them all barring the air screw in No4 which just cannot be removed. This issue is that they are badly seized below the thread, so even drilling out the threaded portion won't work in my experience.
Re: 28mm z1r carb
#6 PostAuthor: Philippe » Fri Apr 12, 2019 1:58 pm
Hi DDZ900
as mentioned above: Z1000ST carbs are a good substitute. The slides of your Z1R carbs fit into the ST carb bodies.
If you should use the third ST carb body, don't forget to block the intake of the vacuum hose for the vacuum fuel tap.
I use ST carbs on my Z1R and they perform very good!
Good luck!
DDZ900
Re: 28mm z1r carb
#7 PostAuthor: DDZ900 » Fri Apr 12, 2019 6:58 pm
Big Cheers Philippe :D
