GPZ1100 B1 vs. Z1 range frame dimensions
Jay1969
#1 PostAuthor: Jay1969 » Thu Apr 25, 2019 2:33 am
Hi everyone.
Are the centre stand lugs, the rear engine mountings,
and swing arm width the same widths apart on these 2 frames?
Re: GPZ1100 B1 vs. Z1 range frame dimensions
#2 PostAuthor: chrisNI » Thu Apr 25, 2019 8:48 am
Hi Jay nice to see you’re back. :D
Without getting the tape measure out I’d guess the answer is no.
8 Valve Mark
#3 PostAuthor: 8 Valve Mark » Fri Apr 26, 2019 6:40 pm
what's the cunning plan jay? centre stand mounts are different both ways i reckon but I've seen plenty of gpz/j motors in Z frames. anything goes as they say!! ps swinging arms are very close, so should be feasible m
neilbarrett
#4 PostAuthor: neilbarrett » Fri Apr 26, 2019 8:06 pm
gpz motor is shorter,you end up with a gap were the kick start used to be
