The hydraulic fitting into the front callipers is a short/stubby male connector, for the hard pipe.
I want to fit a flexi directly to it and a banjo type fitting won’t work as the screw/bolt is too long.
What fitting adapter do I need to use?
Brake calliper hose fitting???
trikerdrew
Re: Brake calliper hose fitting???
no idea-at least I am consistant,LOL!
Do you have a hydraulic hose place near you?
I use Pirtek for stuff like this. Worth a look
Pigford wrote:The hydraulic fitting into the front callipers is a short/stubby male connector, for the hard pipe.
I think it is M10 x 1.25 pitch screws into the caliper. You don't mention what you already have on the end of your flexi but if it is female M10 x 1.25. This should do.
https://auto.helperformance.com/male-to ... m10-x-1-25
needaz1100r
- ZedHead
If you don't yet have a hose, you need this on the end of the hose you get to suit the thread in the caliper, I will check what that is shortly...
https://www.demon-tweeks.com/goodridge- ... lsrc=aw.ds
PS, I will shortly be set up to make custom Goodridge and standard style brake hoses.
Cheers,
Mark.
Mark.
Thanx both Zed Head & Mark
I don't have any hoses yet - so if it's not going to be too long mark, I'd be up for a quote/purchase pleeze?
Cheerz
Cheerz
needaz1100r
- ZedHead
Pigford wrote:Thanx both Zed Head & Mark
Cheerz
It could be a couple of weeks, I'm refusing to hand over the cash for the machine until they sort out dies to make OEM style hoses, so I can make replicas, but also OEM style to custom lengths if needed.
Cheers,
Mark.
Mark.
