Ok I've got some rs34 flatslide carbs on the way
Also a pull push throttle kit .. question is will it fit with the original switch gear or is it best to fit another throttle tube and switch gear from something else.. regards richy
Flatslide carbs rs34 pull push throttle help z1100r
Re: Flatslide carbs rs34 pull push throttle help z1100r
Ive got a motion-pro PPT on mine for the flatslides. The cast boss (cable reel) part is 15mm wide on the bars. If you have drag bars (straights) you are going to run out of room. If you have superbike bars you should be able to just push the switch-block and master cylinder a little further along with a small adjustment to you hand hold.
Cheers AL I've got standard zrx1200 bars on hope there is enough room regards richy..
