Locating plate J,R GPz rhs switch
#1 PostAuthor: chrisNI » Tue May 14, 2019 8:35 pm
As above wanted a Locating plate for J,R GPz rhs switch. If anyone has a broken or incomplete switch they don’t need all I need is the metal plate which screws inside that has the small locating spigot for the bars. The previous owner ground them off in his enthusiasm to fit Renthals meaning the switch turns unless it’s over tightened, I’m putting the standard bard back on having got them re-chromed, if anyone has one of these they don’t need it would save a bit of arsing about. At the same time if there’s a longer screw from that switch (5x40 black) in good shape I’d like one of those too...
I don’t know why people butcher switches instead of drilling a small hole in the new bars, my mate bought a ZRX they guy had done the same thing except the Rex pin is plastic they’d just broken them off... :shock:
Anyway here’s the bit I need, the metal plate held In by the two wee screws. It should have a protruding spud where the grind mark is... thanks in advance :Oo :shock: :lol: :lol:
Re: Locating plate J,R GPz rhs switch
#2 PostAuthor: paul doran » Tue May 14, 2019 9:21 pm
I have one Chris
#3 PostAuthor: chrisNI » Tue May 14, 2019 9:38 pm
Paul I’ll give you a call tomorrow evening :D
tlc
#4 PostAuthor: tlc » Wed May 15, 2019 8:45 am
I’ll have one as well if Paul struggles.
#5 PostAuthor: paul doran » Wed May 15, 2019 8:47 am
I definitely have one
and I am a bit closer
Julian_Boolean
#6 PostAuthor: Julian_Boolean » Wed May 15, 2019 12:19 pm
I've got a whole switch if you want it
#7 PostAuthor: chrisNI » Thu May 16, 2019 8:55 am
Thanks for the help sorted :D
