Fuel Tap
mickthevin
- new poster
Fuel Tap
Bit confused - my z1000a2 has a fuel tap with 3 outlets - all diagrams I have show 2 outlets. One is the the main outlet at the bottom and then have 2 outlets at the back of the tap. Had the tank off the other day and since putting it back on the bike wont start. Checking to see if its fuel starvation and think I might have put the hoses on the wrong way. Both of the outlets at the back are the same size and the hoses go between 1 and 2 carbs and the other 3 and 4. Can anyone advise - Mick
Re: Fuel Tap
Mick, the third one is the vacuum pipe to pull in the diaphram. It feeds off the manifolds.
Re: Fuel Tap
Hi Mick
the third pipe should be connected to the number 3 carb to create a vacuum in order to allow the diafragm in the tap to open.
If you put the lever of the tap on "pri" the fuel will run to the carbs without the engine running.
Good luck
Good luck
