more 900 parts cylinder head
glav666
#1 PostAuthor: glav666 » Thu Jun 06, 2019 6:33 pm
z900 cylinder head with cam caps had some thread repair, all good now, no valves. usual crakes between plug and valves
All plus postage from Belfast to you all prices negotiable
Cylinder head £150
engine bars need a good clean, with long engine stud £45
Z Power new left metal brake pipe £12
Front spindle and spacer £15
Torque arm stamped painted so needs rechrome £10
Rear sets, look sorta home made sorta not , need rechrome £60
glav666
Re: more 900 parts cylinder head
#2 PostAuthor: glav666 » Mon Jun 10, 2019 7:19 am
Rear sets sold
PJONO
#3 PostAuthor: PJONO » Wed Jun 12, 2019 11:42 am
Hi
Did you get my last PM re the engine bars and back axle?
jonhunt
#4 PostAuthor: jonhunt » Wed Jun 12, 2019 11:57 am
Just as info. I have a head with 8 separated bearing caps. Assume that’s a earlier 900
8 Valve Mark
#5 PostAuthor: 8 Valve Mark » Wed Jun 12, 2019 6:39 pm
jonhunt wrote:Just as info. I have a head with 8 separated bearing caps. Assume that’s a earlier 900
I've only ever seen 4 caps jon... hmm...how bizzare , how bizzare....
glav666
#6 PostAuthor: glav666 » Thu Jun 13, 2019 8:27 am
I don't think so, I think it was original to my 76 A4. Maybe someone else can shed more light on it.
jonhunt
#7 PostAuthor: jonhunt » Thu Jun 13, 2019 12:31 pm
Ignore my comment. Had a quick dig around in the garage caps are The same.
Return to “For Sale”
