Re Fitting tyre stoppers to lester rear mag
snowyz9
#1 PostAuthor: snowyz9 » Wed Jun 12, 2019 4:05 pm
Hi
Was thinking about fitting tubes into my newly re furbed Lester Mags on z1000A2 , Question the rear wheel is drilled to accommodate the stock wheel tyre holders , with fitting a tube , is it ok to not use them and rim tape the centre of the rim ?
Re: Re Fitting tyre stoppers to lester rear mag
#2 PostAuthor: chrisu » Wed Jun 12, 2019 5:30 pm
Absolutely
8 Valve Mark
#3 PostAuthor: 8 Valve Mark » Wed Jun 12, 2019 6:34 pm
you'll still have extra holes in the rim though :rock
snowyz9
#4 PostAuthor: snowyz9 » Wed Jun 19, 2019 12:03 pm
Rim tape
Charlie
#5 PostAuthor: Charlie » Wed Jun 19, 2019 3:25 pm
Tyre stoppers/tyre grabbers/rim locks/wheel grabbers - multiple names for the same things :wink:
I used some M8 button head screws and nuts on my alloy wheel. There is no need for rim locks fitting anyway, the old Zeds would struggle to remove rice pudding skin, let alone tear valves out of tubes :)
When these are fitted though, they look like rim locks ARE fitted and you dont leave unsightly holes in the rim. A rim tape or similar neatly covers the head inside the wheel
snowyz9
#6 PostAuthor: snowyz9 » Wed Jun 19, 2019 9:11 pm
Thanks Charlie
Users browsing this forum: Google [Bot] and 111 guests
