Gear shift drum plate
GreenMamba
#1 PostAuthor: GreenMamba » Sun Jul 07, 2019 1:56 pm
Hi guys I’m after the plate that gets bolted onto the gear change drum item 20 in the pic for a Z1R but I think it was a common part across ranges let me know what you got thanks
8 Valve Mark
Re: Gear shift drum plate
#2 PostAuthor: 8 Valve Mark » Sun Jul 07, 2019 9:49 pm
hi Greenmamba, judging by the silence; I'd say they're kinda scarce! the trouble is; once removed from the drum; both the drum n the end-plate are worthless without each other..if that makes sense? anyhow!!! I've got a whole assembly i could live without, n happy to help mate. m
GreenMamba
#3 PostAuthor: GreenMamba » Sun Jul 07, 2019 10:07 pm
Yes the silence was deafening! You sir are a gent what do I owe you and where can I cannot me collect it from you?
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Mon Jul 08, 2019 2:03 am
you can i cannot collect it from me can post to you! thimples..
GreenMamba
#5 PostAuthor: GreenMamba » Mon Jul 08, 2019 7:20 am
Wow autocorrect really sucks bum sometimes. So would you rather post it?
