Hi, does anyone know the part no. or the size of the o'ring between the reservoir and the body of the rear master cylinder on the MK2?
Thanks in advance.
MK2 rear master cylinder
mark burch
Re: MK2 rear master cylinder
Just a reminder for my previous question, any info greatly received, thanks
mark burch
This is the Kawasaki diagram from CMSNL for an 1980 A4 Z1000. There appears not to be a separate part listed there.
Hi shorty
the O-ring is not sold seperately by Kawasaki.
You'll have to find one or make one yourself.
It's a square O-ring, the outer diameter is 52 mm, the height is 2,85 mm and it has a width of 2,35 mm
Don't forget it has to be brake fluid resistant!
Good luck
Good luck
