petrol tank clean
BENCLARK
petrol tank clean
#1 PostAuthor: BENCLARK » Mon Aug 05, 2019 11:45 pm
hi z fans
whats the best method for cleaning the inside of a petrol tank??
Back in the early eighties i seem to remember using pea gravel, counting the gravel in and out using fuel as an aggregate
any advice welcome
Ben
KeithZ1R
Re: petrol tank clean
#2 PostAuthor: KeithZ1R » Tue Aug 06, 2019 6:51 am
Cheap full sugar coke and Acid based toilet cleaner 3:1 leave for seven days rinse with white spirit or turps, remove the tap and sender (if fitted )or it wil destroy them
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Pauldonjuan
#3 PostAuthor: Pauldonjuan » Tue Aug 06, 2019 6:51 am
Hey, I've found electrolysis works a treat for me every time. Very simple and effective.
Mathh
#4 PostAuthor: Mathh » Tue Aug 06, 2019 7:43 am
Pauldonjuan wrote:Hey, I've found electrolysis works a treat for me every time. Very simple and effective.
I agree, I have done all my tanks with this method... Then phosphoric acid to prevent it from rusting again...
scott
Junior Section leader
#5 PostAuthor: scott » Tue Aug 06, 2019 8:12 am
The Harpic and coke method works surprisingly well. Spotless inside when finished. Importantly it's disposable via the drain and not some chemical nasty that requires proper disposal.
#6 PostAuthor: Ultim8pc » Tue Aug 06, 2019 9:11 am
I use phospohoric acid.
Andrew_s
#7 PostAuthor: Andrew_s » Tue Aug 06, 2019 10:38 am
What's the state of the paintwork, are you intending to have it repainted?
If not, be careful on what product you use otherwise you may damage the existing paint.
Current Bikes:
2023 R1250 GSA
#8 PostAuthor: ZedHead » Tue Aug 06, 2019 12:20 pm
The active ingredients are dilute Phosphoric Acid in cola and dilute Hydrochloric Acid in Harpic
The Hydrochloric removes rust while Phosphoric converts it to a stable material ferric phosphate.
Bio preparations are less hazardous and work well.
scott
#9 PostAuthor: scott » Tue Aug 06, 2019 12:26 pm
So long as you get no over spill things should be fine. I treated my A2 tank which was fully painted etc, i just made sure during the filling process that it did not bubble over. Don't let it bubble over!!!
BENCLARK
#10 PostAuthor: BENCLARK » Tue Aug 06, 2019 6:23 pm
Thanks to all for very helpful advice.
what would be the best method to seal up the sender and fuel tap recesses.
buy a couple of donor parts and fit them??
scott
#11 PostAuthor: scott » Tue Aug 06, 2019 6:36 pm
I made plates with drilled holes for the bolts then cut some gasket to size.
johnA
#12 PostAuthor: johnA » Tue Aug 06, 2019 7:22 pm
citric acid removes rust really well and wont damage your paint if you spill any.
#13 PostAuthor: ZedHead » Tue Aug 06, 2019 7:30 pm
johnA wrote:citric acid removes rust really well and wont damage your paint if you spill any.
I like that!
FYI the acidity of the Phosphoric Acid in Cola is only around 0.017%. I am not too sure that sugar ads much to the process. Unless you intend to drink it after :shock:
Blackseven
#14 PostAuthor: Blackseven » Tue Aug 06, 2019 8:27 pm
Bilt Hamber Deox C is made for this job and worked well for me.
Afterwards I neutralised it with Acetone (cheap Tesco Nail Polish remover) and then swilled some WD40 round the inside to protect it until I was ready to use it.
johnA
#15 PostAuthor: johnA » Wed Aug 07, 2019 4:51 pm
i think deox c is just re branded citric acid with the price bumped up a bit.
