Hi Guys,
I have three rust hole on my Z1 tail pipe, doesn't look too bad, but can anyone recommend a repairer/chromer to patch and rechrome?.....is it really possible?
Sure a few of us have had this problem before!
The rest of the pipe appears to be solid
Rob
Exhaust Rust Repair
Exhaust Rust Repair
- Attachments
- IMG_1622.jpg (58.29 KiB) Viewed 2880 times
- IMG_1621.JPG (95.4 KiB) Viewed 2880 times
paid up member
Re: Exhaust Rust Repair
One of mine has a piece of shaped steel brazed in and does not look to bad un-chromed. I was advised that few platers will touch it due to risk of tank contamination and unseen rust leading to the pipes dissolving.
not many chrome platers will re chrome a rusty exhaust unless it has been thoroughly chemically cleaned which then makes the exhaust rust even quicker as soon as it gets condensation in it & then little pin holes start appearing a few months after you have shelled out a few hundred quid save your money & buy a repro set from dave
- warren3200gt
ZedHead wrote:One of mine has a piece of shaped steel brazed in and does not look to bad un-chromed. I was advised that few platers will touch it due to risk of tank contamination and unseen rust leading to the pipes dissolving.
How have you stopped the uncoated steel from rusting Dave?
believe steve smethurst does exhaust repairs,
warren3200gt wrote:ZedHead wrote:One of mine has a piece of shaped steel brazed in and does not look to bad un-chromed. I was advised that few platers will touch it due to risk of tank contamination and unseen rust leading to the pipes dissolving.
I just keep it polished, seems to work.
Users browsing this forum: No registered users and 135 guests
