Z1a Z1b Z900a4 master cylinder
SINGLE DISC USE
I polished this up and rebuilt it.
I'm pretty sure it will need another rebuild as it makes a squelchy noise when you pull the lever.
Genuine part stamped on the bottom
£20 posted to mainland UK postcodes.
Master cylinder Reduced see below!
Z900a4, BMW 1200GS, H-D 1200, KTBFFH
Re: Master cylinder reduced see below
New one arrived from cybike works great!
This is now £20 as I noticed new one did not make a squelchy noise when you pull the lever and this does so i guess the rebuild kit is not fitted as it should be.
