Hello from sleepy Suffolk
Futter
#1 PostAuthor: Futter » Wed Sep 18, 2019 4:11 pm
Hi all. Currently looking at a 1980 z1000st. It's a bit of a rat/survival machine and far from standard. Having said that it is sound and solid. What are the main issues to look for, problems that arise etc. It may have the 1075 big bore kit on it and it certainly goes like a scalded cat so not unhappy with that. Carbs weeping slightly and the tank seems to leak a bit but it's on the seam rather than rust. It's chopped up a bit but would suit me.
Thanks in advance
Birth school ride die
Re: Hello from sleepy Suffolk
#2 PostAuthor: Philippe » Wed Sep 18, 2019 6:09 pm
Hi Futter
Welcome to the club!
If it's an ST just go for it! Give it fuel in the tank, oil in the engine and air in the tires and ride it.
Beware, it's heavy and powerful !
Show us some pictures, we all like them .
I'm an ST fan too and have five of them in my collection, I know them inside and out so if you have any questons, just ask!
Greetings from Belgium
Futter
#3 PostAuthor: Futter » Wed Sep 18, 2019 7:06 pm
This is what I'm looking at. :ghostface
Possibly mine
#4 PostAuthor: deka » Wed Sep 18, 2019 9:00 pm
Ask philippe he is a mine of information on st,s Welcome and as he says. Go for it
#5 PostAuthor: Philippe » Thu Sep 19, 2019 3:56 am
Hi Futter
JC that's a monster! The rear section of the frame has been chopped off and replaced by something else! :shock:
Can you get it MOT'ed ? If not, don't buy it.
But if you like it, go for it. It's not my piece of cake and I would never ride such a Mad Max bike . :ghostface
Does it handle well at higher speeds? Think about your safety!
Futter
#6 PostAuthor: Futter » Thu Sep 19, 2019 5:15 am
That's the thing with rat bikes..... They look like they do but are totally legal. The exhaust came from a z1 engined Harris and the plate is side mounted on the left. Other than what I mentioned my only other concern is the electrics. The headlights seem really poor and I will get a more original headlight but is the charging system a weakness on these bikes?
Oh and as of next year it will be tax and not exempt.
Futter
#7 PostAuthor: Futter » Thu Sep 19, 2019 5:17 am
It handles ok. The geometry hasn't changed, just the riding position. I found it heavy in the corners as well.
Julian_Boolean
#8 PostAuthor: Julian_Boolean » Thu Sep 19, 2019 8:10 am
Hello Futter, just buy it.
#9 PostAuthor: ADRIAN H » Thu Sep 19, 2019 8:33 am
Futter wrote:I found it heavy in the corners as well.
Most zeds are heavy in the corners. Headlights are generally poor on these 1970's bikes, but you have got some spot lights as well.
Charging system is generally up to the job, if you may want to fit a combined regulator / rectifier, (www.electrexworld.co.uk sell them).
Futter
#10 PostAuthor: Futter » Thu Sep 19, 2019 8:59 am
Julian_Boolean wrote:Hello Futter, just buy it.
Hello buddy ..... You seem to get everywhere!
Futter
#11 PostAuthor: Futter » Thu Sep 19, 2019 11:47 am
Also, what's the best way to upgrade the brakes? It's fitted with braided hose but would different calipers help? If so which ones?
Paulb
#12 PostAuthor: Paulb » Fri Sep 20, 2019 8:50 am
hello Futter
Suffolk won't be quite as sleepy if you buy that. Great bike.
Z900A4.
Ducati Streetfighter V4 S
