This item has been sold!
I am selling a Takasago rim and a hub from a Z1 from march 1973, production code in the rim is 3C 303. There are no codes visible on the hub. The rim is nice and straight with no dents. It had a bit of rust which came off easy almost completely . The rim should be polished for a better result. For an expensive nut and bolt restauration I suggest a rechrome though. Better and bigger pics on request. Will figure out shipping cost from the Netherlands to the UK in a couple
Z1 1973 rim and hub (Sold)
