Black Fuel Tap (73)
Black Fuel Tap (73)
As title, looking for a original 73 fuel tap ,black THKs
Re: Black Fuel Tap (73)
https://www.ebay.com/itm/Kawasaki-Z1-90 ... ondition=4
Warning: 73 z1 used a rubber sleeve, no longer available.
The tap levers shown are the early 73 type without the later added O ring and leak badly.The replacement seal is the part also needed on a tap rebuild but are hard to come by.The later levers c/w 'O' ring are available on ebay.
Regards
Steve
Regards
Steve
wilsonsjw11 wrote:The tap levers shown are the early 73 type without the later added O ring and leak badly.The replacement seal is the part also needed on a tap rebuild but are hard to come by.The later levers c/w 'O' ring are available on ebay.
Regards
Steve
Thanks 4 that ,so do the later levers with 0 ring fit early tap bodies .
Yes they do.
Any chance of buying a pan head screw , that holds the lever in place , you kind gentleman
All sorted bar the filters ,now this turns up typical - https://www.ebay.co.uk/itm/KAWASAKI-197 ... SwwKpdwXL5
Put the original tap on , but lets a bit of fuel out on the off position , so back on with the repro one.Well i Tried !
You need the replacement seal for the rebuild to be successful.
Regards
Steve.
Regards
Steve.
wilsonsjw11 wrote:You need the replacement seal for the rebuild to be successful.
Regards
Steve.
The only seal I have not replaced is the rubber sleeve that slides on to the lever, is this the one that needs replacing , thanks for the input by the way
The seal you have described is the item required,if you get one apply red rubber grease when rebuilding the tap and on yearly basis to keep it soft and pliable.
Regards
Steve
Regards
Steve
does anyone have an image of one fitted to the lever?
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
That is the seal, the tap lever is new?
Regards
Steve
Regards
Steve
