4 0r 6 pot tokico front brake calipers
4 0r 6 pot tokico front brake calipers to fit zx6r front forks , 90mm between bolt holes please
Re: 4 0r 6 pot tokico front brake calipers
go for 4 pot.
most people change out their 6 pots to nissin 4 pots.
garyd wrote:go for 4 pot.
I agree, with correct pads the 4 pots brake as good as the 6 pots. Even the Tokico 4 pots. 6 pots are heavier though.
- Ginger Bear
Bunny, most s/h will be shite/seized. Take the time to strip your originals, send the bodies to Flying Tiger o be ceramically coated, then rebuild with new seals.
If you do buy s/h, calipers from Suzuki's have anodised aluminium pistons, where as Kawasaki have chrome plated steel, which doesn't stand up to corrosion as well as the aluminium.
Just get cracking with your hammer and screwdriver!
I have got a set of Tokico 4 pots with pads, in what looks like decent condition, I'm away for the weekend, can get some pics if interested
Ginger Bear wrote:Bunny, most s/h will be shite/seized. Take the time to strip your originals, send the bodies to Flying Tiger o be ceramically coated, then rebuild with new seals.
Those calipers look gorgeous. How much for the Flying Tiger treatment?
- Ginger Bear
Simonic wrote:Those calipers look gorgeous. How much for the Flying Tiger treatment?
I really can't remember, although I don't recall being shocked. Quick turnaround too in that department.
Had all pins and fasteners polished and black zinced by Mikey.
