Fuel Tap Black 73 Brass Fitting
Re: Fuel Tap Black 73 Brass Fitting
Maybe a silly idea. But what about soldering the crack insitu ?
Heat the tap up after stripping it down, the brass will pull out, make or buy pipe of correct size, warm up tap freeze pipe and push pipe in
I have successfully soldered carb overflow tubes in the past, cleanliness is the key and a pen torch, see no reason why should not work there.
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
mick.harris
- Regular Poster
I've a spare if it helps you out, I've sent you a P.M.
I had the same issue.
I fixed it by pushing another piece of brass pipe over the damaged one.
Hi Guys
Thanks for getting back to me, I will try the ideas you have and see how I get on.
I am not great at soldering, do you know where I might get a same size length of brass pipe.
Regards Irishkev
Regards Irishkev
Available on EBay,- brass tube 2mm - 7mm
Seller - maccmodels
Seller - maccmodels
