Does the early petrol tank, side panels and tail from a Z1A fit any other versions ie Z1000 and Z900s?
Mark
Panels and Tank Interchangeability
Re: Panels and Tank Interchangeability
The tank and tail will you need to modify a few things to make the side panels fit
Thanks for that so it is "do able". I wanted to preserve my original setup and fancied a colour change.
You can buy replica side panels from the Club which are better than original and very reasonably priced and you will get whatever set you need to fit without butchering (sorry modifying)
Gus
Gus
"Set the GRINDER on it"
Hi Mark
as Chris allready mentioned: the tank and tail piece will fit.
The side panels of a Z1,Z1A and Z1B will not fit to a Z900A4 or a Z1000. You need to change the place of the holes in the frame in order to attach them. You allso have a problem with the shape of the air filter box. The air filter box of a Z1,Z1A, Z1B has a different shape (smaller) compared to the one of a Z900A4 or Z1000 (bigger and more or less "square").
The left hand side panel of a Z900A4 and a Z1000 have the same shape, you can easily mix those but the right hand side panel of a Z900A4 is not the same as the one of a Z1000. The lower lug of the right hand side panel of a 900A4 is more or less in the middle, the lower lug of a Z1000 side panel is more towards the front. Keep that in mind when ordering replica side panels!
And not forgetting that the Z1/A/B tail piece has a rounded profile to match to oval rear light where as the A4 is more squared off to match the square-ish A4 light. In my eyes it doesn't look right if they are mismatched.
I see Zed people.
zapo wrote:And not forgetting that the Z1/A/B tail piece has a rounded profile to match to oval rear light where as the A4 is more squared off to match the square-ish A4 light. In my eyes it doesn't look right if they are mismatched.
The square light is horrible and doesn’t have a built in reflector either, in my eyes they don’t look right even matched - Z1000s are much improved with addition of the “proper” tailpiece and rear light
