6mm crankcase bolts
6mm crankcase bolts
Evening peeps, as the title says looking for any 6mm thread 10mm head crankcase or sump bolts, any length any condition. Buzzard
Every man should have a shed (for bikes obviously..)
- warren3200gt
Re: 6mm crankcase bolts
Should have plenty of 650 bolts for sump, crankcase and cam cover. I swopped em out for stainless socket head on my custom build. I'll check it out tomorrow. Anything in particular your after?
Afternoon Warren, I'm restoring a Z1A 900 to original condition, unfortunately the engine was previously assembled using Allen screws, so what I'm after is any length 6mm thread crankcase/sump bolts, the type that are 10mm head with the built in washer, from 25mm length up to the very long ones 116mm, any condition any length. Thanks. Buzzard@thebuzzworkz
- warren3200gt
Hi Buzzard, found a few, see pic.Dims refer to underside of head to end of thread. Any of these any good to you? Damn Australian bolts!
Warren, there spot on, how much do you want for all of them? I already have a few but none of the smaller ones. Thanks. Buzzard@thebuzzworkz
- warren3200gt
Ping me your adress and I'll get them out to you mate.
Bolts arrived Warren, massive thanks. Buzzard@thebuzzworkz
needaz1100r
- ZedHead
buzzard wrote:Afternoon Warren, I'm restoring a Z1A 900 to original condition, unfortunately the engine was previously assembled using Allen screws, so what I'm after is any length 6mm thread crankcase/sump bolts, the type that are 10mm head with the built in washer, from 25mm length up to the very long ones 116mm, any condition any length. Thanks. Buzzard@thebuzzworkz
http://www.z-power.co.uk/bolt-set-crankcases-6mm
Cheers,
Mark.
Mark.
