A4 carbs
A4 carbs
#1 PostAuthor: paul doran » Wed Jan 01, 2020 4:33 pm
I have a set of A4 cars belonging to a friend
The two fuel inlet t pieces are a very loose fit into the carb bodies
Any ideas
Re: A4 carbs
#2 PostAuthor: warren3200gt » Wed Jan 01, 2020 5:21 pm
Are they o ring t's or solid Paul? O rings easily replaced or if solid new available from allens performance or ptfe plumbers tape.
PUM 488 June 2020
76 Z900A4, 77 Z650B1, 77 KZ650B1, 77 Z1000A1, 82 Z1000J2, 89 ZXR750H1, ZRX1100R.
Re: A4 carbs
#3 PostAuthor: kev edwards » Wed Jan 01, 2020 5:41 pm
I do know when soaked in fuel they will expand and do the job, but if they dry out again they will leak, some cut the o ring shaped pieces off and use new o rings, me, i made new brass tee's that were a snug fit and bought o rings.
kz900B1
Re: A4 carbs
#4 PostAuthor: kz900B1 » Wed Jan 01, 2020 6:10 pm
Hi Paul, I replaces mine last year with these .
https://www.cybike.co.uk/Shop/Products/ ... nnector-z1
Also available is a Brass version with o rings .
https://www.cybike.co.uk/Shop/Products/ ... fuel-pipe1
colinKZ900B1
Re: A4 carbs
#5 PostAuthor: Ultim8pc » Thu Jan 02, 2020 9:39 am
Paul
Common problem. The rubber dries out due to the lack of petrol.
If the rubber is not cracked, then soak them in cellulose thinners for an hour or so. This swells the rubber back up.
If you decide to replace them you can go with the OEM ones or the brass ones with orings. Deepends if you want originality or not.
http://www.quick-glo.co.uk
ZRX1200r - on the road
z900a5 - on the road
z1a - to restore
z1000a1 - In bits
Z1000 MK2 - to restore
z1000ST - in bits
Re: A4 carbs
#6 PostAuthor: chrisu » Fri Jan 03, 2020 8:40 am
Agree. I replaced mine
Users browsing this forum: Google [Bot] and 19 guests
