carb problems...(air filters/jets).........HELP !!!!!!
domz
#1 PostAuthor: domz » Sun Apr 20, 2008 5:58 pm
Recently bought new vance & hines, air filters & jets. Changed the exhaust...LOVELY...ran really well...next day changed the air filters from standard box to k&n's, the pilot jet from 15 to 17.5 and main jet from 102.5 to 110...now runs like a bag of old s**t seems like she's constantly choking....any ideas ????????????
mikey
#2 PostAuthor: mikey » Sun Apr 20, 2008 6:50 pm
Well im no expert ( theyll be along after me ) but when i got my A2 it had k&ns bigger jets and ran like a bag of crap got a standard airbox, filter and jets and it ran properly thats my expierience
#3 PostAuthor: Pigford » Sun Apr 20, 2008 7:01 pm
The standard Kawasaki carbs are a pain to sort with pod filters (K&N's) :evil:
Try 115's....., best to start rich then reduce jet size :wink:
mikey
#4 PostAuthor: mikey » Sun Apr 20, 2008 7:22 pm
See told you an expert would be along after me :D
domz
#5 PostAuthor: domz » Sun Apr 20, 2008 7:37 pm
thanks for your experience mikey but gonna stick with it for the mo...and as for going up another 2 sizes...will that be enough pigford ???? I was thinking along these lines earlier today...loads more air going in need huge jets (boeing 747 springs to mind) or am i just talking shit again ????
#6 PostAuthor: Pigford » Sun Apr 20, 2008 7:57 pm
Rule of thumb is a good 10% increase for hi-flow filters..... but every case is different :wink:
domz
#7 PostAuthor: domz » Sun Apr 20, 2008 8:24 pm
ok thanks for that will buy some 115's and 112.5's just in case....any recommendations as to a supplier that can deliver yesterday got the bristol & west coming up shit loads of work to do so very little time to play with the old girl...and the bike !!!!!!!!!
debben1
#8 PostAuthor: debben1 » Mon Apr 21, 2008 1:15 pm
Hello Domz, I would guess at something around a 122.5 to 125 main jet size, pilots should not need to be bigger than 17.5, where are the needles set ? this will have a far greater effect on fueling than the main jets and costs nothing to try, Regards, Steve
domz
#9 PostAuthor: domz » Wed Apr 23, 2008 8:08 am
hi steve thanks for the advice will certainly try 122.5's when i can find somewhere that actually sells main jets phoned z supplies yesterday and no joy.............in the meantime took out the float needle to alter the setting and found that it only has the '1' setting so a bit stumped at the mo !!!
Dark Skies
#10 PostAuthor: Dark Skies » Wed Apr 23, 2008 12:05 pm
domz wrote:hi steve thanks for the advice will certainly try 122.5's when i can find somewhere that actually sells main jets phoned z supplies yesterday and no joy.............in the meantime took out the float needle to alter the setting and found that it only has the '1' setting so a bit stumped at the mo !!!
Try here:
http://www.allensperformance.co.uk
http://www.allensperformance.co.uk/mikjets.html
http://www.allensperformance.co.uk/jetsizeconv.html
KZ1000-M1 CSR
RALPHARAMA
#11 PostAuthor: RALPHARAMA » Wed Apr 23, 2008 2:13 pm
Steve Debben can supply you jets - I think!
Ralph Ferrand
#12 PostAuthor: Pigford » Wed Apr 23, 2008 4:44 pm
Domz, I got a set you can have, gimme ur address mate :wink:
#13 PostAuthor: Rich » Wed Apr 23, 2008 5:38 pm
Steve doesn't mean float needle :roll: he means the needle that works in conjunction with the needle jet - the one in the centre of the slide.
domz
#14 PostAuthor: domz » Wed Apr 23, 2008 9:57 pm
that be the one with the circlip round it that I happened to call the wrong name...you'd be amazed at how much trouble that getz me into with the misses...ha ha !
domz
#15 PostAuthor: domz » Wed Apr 23, 2008 10:00 pm
Thanx to dark skies for the attachment :D
Users browsing this forum: No registered users and 81 guests
