Fuel pipe
snowyz9
Fuel pipe
#1 PostAuthor: snowyz9 » Wed Jan 22, 2020 5:00 pm
What fuel pipe are you guys using z1000 , I have noticed that the kit sold by z power , the ends that go onto the carbs and fuel tap , they go solid like plastic in a short time .
Re: Fuel pipe
#2 PostAuthor: warren3200gt » Wed Jan 22, 2020 5:11 pm
Here you go Snowy, fill yer boots at a fraction of the cost.
https://www.advancedfluidsolutions.co.u ... r-90-c.asp
Tonto
Re: Fuel pipe
#3 PostAuthor: Tonto » Wed Jan 22, 2020 5:27 pm
Snowy, in the past I've also used some hose from Z Power and its gone rigid before fitted my tank on :shock: - was only used a couple of times from my auxilliary petrol tank - now thrown it in the bin.
Since changed to Nitrile (NBR) - its meant to be far more resistant, and does seem better.
Cheers Tim
snowyz9
Re: Fuel pipe
#4 PostAuthor: snowyz9 » Wed Jan 22, 2020 5:41 pm
Warren did you get the 6mm , comes out 5.4mm
snowyz9
Re: Fuel pipe
#5 PostAuthor: snowyz9 » Wed Jan 22, 2020 5:47 pm
Warren , did you use the 6mm , 5.4 real
Re: Fuel pipe
#6 PostAuthor: warren3200gt » Wed Jan 22, 2020 5:51 pm
Cant recall mate. I bought 5m of several sizes as its cheap, as I seem never to have a length of syphon hose when I need it!
Fraction of the cost for overflow pipes.
snowyz9
Re: Fuel pipe
#7 PostAuthor: snowyz9 » Sat Jan 25, 2020 7:46 pm
Thanks Warren , fuel pipes great and fast post from your guy.. 7.2 I'd was perfect
Re: Fuel pipe
#8 PostAuthor: warren3200gt » Sat Jan 25, 2020 8:20 pm
:up
Users browsing this forum: Stugill and 64 guests
