KZ1000 LTD front turn signals
Arnold62
#1 PostAuthor: Arnold62 » Wed Feb 19, 2020 12:39 pm
Been trolling on Johnnys vintage motorcycles, noticed how nice a LTD looks when turn signals are repositioned either side of headlamp, looks straight forward but does anyone have any knowledge regarding parts needed or done this mod?
Thanks in advance
Re: KZ1000 LTD front turn signals
#2 PostAuthor: kev edwards » Wed Feb 19, 2020 3:38 pm
go for CSR 1000/650 front indicators/signals on ebay you will find some on there, i have a set but i don't know what happened to the clamps.
https://www.ebay.co.uk/itm/Kawasaki-Z44 ... SwUYtdztcP
Arnold62
#3 PostAuthor: Arnold62 » Wed Feb 19, 2020 4:27 pm
I was thinking of using the Z1 stems and flashers.
Arnold62
#4 PostAuthor: Arnold62 » Wed Feb 19, 2020 4:51 pm
As per this picture.
#5 PostAuthor: kev edwards » Wed Feb 19, 2020 5:33 pm
I was on a different page, I have them on my Ltd, I just bought the whole part and they fit straight on
Arnold62
#6 PostAuthor: Arnold62 » Wed Feb 19, 2020 7:39 pm
kev edwards wrote:I was on a different page, I have them on my Ltd, I just bought the whole part and they fit straight on
Do they need the correct rubber as usually fitted in normal Z1 headlamp brackets?
#7 PostAuthor: kev edwards » Wed Feb 19, 2020 7:57 pm
No i don't have original style rubbers ltd headlamp bracket not the same, but i put some 2mm rubber between stem and bracket, here is a pic, bit dusty, been sawing some timber up in the garage.
Arnold62
#8 PostAuthor: Arnold62 » Wed Feb 19, 2020 8:05 pm
kev edwards wrote:No i don't have original style rubbers ltd headlamp bracket not the same, but i put some 2mm rubber between stem and bracket, here is a pic, bit dusty, been sawing some timber up in the garage.
Just the look I’m after, thank you.
Arnold62
#9 PostAuthor: Arnold62 » Sun Mar 22, 2020 9:20 pm
Just got Z1 chrome stems, did you enlarge the hole in headlamp mounting bracket, or make it the same shape as the stem, it’s got that oval shape on the stem?
Need to factor in headlamp aim/adjustment too.
