Does anyone have a gpz1100b1 speedo clock/instrument that they would sell. I just need the speedo clock and not the whole instrument cluster but if a set of clocks is offered with a naffed tacho that would be exceptable. I don't need the tacho, already have one in my B2 clocks.
Reason: I have a set of B2 clocks which has an electronic tacho and an analogue speedo. I know the B1 has an electronic speedo. My Dymag wheels that are fitted have no facility for a speedo drive. I have a magnetic pickup on the wheels that connects to a external digital speedo clock. It would be nice to install the B1 speedo clock into the B2 instrument cluster....can do away with the external digital speedo clock then. Makes sense, maybe.
Gpz1100b1 speedo/instrument
Re: Gpz1100b1 speedo/instrument
Hi scott
take a look at this:
https://www.ebay-kleinanzeigen.de/s-anz ... 2-306-8822
I hope you can do something with it.
Thanks Philippe, it's in KPH, so will have to look in to how to convert to MPH.
Will Barber (a member here on Z1OC) does great speedo overlays:
https://www.ebay.co.uk/itm/KAWASAKI-GPZ ... SwMNxXUqMJ
The odometer is a separate unit and is the same as the Z1000J and a few other models, so easy enough to convert to miles from kilometers. A careful use of a dremel, and some silicone, and you can reset the mileage:
https://www.ebay.co.uk/itm/Kawasaki-Z11 ... Sw9mtd~kmf
Thanks Mike.
MikeP wrote:Will Barber (a member here on Z1OC) does great speedo overlays:
Pretty sure you’d have to change the gearing on the speedo to get true mileage readings.
Users browsing this forum: Google [Bot] and 58 guests
