Okay chaps,
See the bit I've circled (r/hand side of engine under ignition casing), there's a splined shaft with lever attached behind the oil feed pipe - WTF does it do?
Had to ask as being a bit bored at work was puzzled by what it could be.
Zephyr 1100 engine part identification?
Re: Zephyr 1100 engine part identification?
It is the balancer shaft lever Mark.
Ah, thanks chaps, learn summink every day.
