gpz1100 hydraulic clutch
pluto
#1 PostAuthor: pluto » Tue Apr 14, 2020 1:48 pm
Hi All,
I am wanting to fit a hydraulic clutch conversion on the cheap. I have a spare sprocket cover and want to bolt on to the outside a suitable slve cylinder. Anybody else done it this way and can recommend a suitable cylinder?
Dave
Julian_Boolean
Re: gpz1100 hydraulic clutch
#2 PostAuthor: Julian_Boolean » Tue Apr 14, 2020 1:53 pm
Hi Dave, I've got a Tom Forde conversion bracket, it uses a ZXR750J2 slave cylinder and I've got a ZX9r master cylinder, but the bracket doesn't do anything a flat plate of ally wouldn't do so long as the holes were in the right places, you'd need to hold the plate on with long M6 bolts, but this is all that holds the original casing on, just remember all the pressure pulls on these bolts and there is no push on them.
