Reg/rectifier plug, starter lead
tim.25
#1 PostAuthor: tim.25 » Sat Apr 18, 2020 10:15 am
Hi,
Has anyone got an old 900a4 reg or rectifier plug they don't need you may have cut off at some point?
Looking for a white or green one, a few wires left on would be good.
Also looking for a starter motor lead for the same.
Many thanks.
Tim
Z900a4, BMW 1200GS, H-D 1200, KTBFFH
moizeau
Re: Reg/rectifier plug, starter lead
#2 PostAuthor: moizeau » Sat Apr 18, 2020 11:08 am
Don't know if its the same but I've got a white one off my ST. 3 yellow wires on one side, a black and brown opposite with the middle pin missing. About 2 inches of wires still on. If it's any good and no-one closer has one your welcome to it.
tim.25
#3 PostAuthor: tim.25 » Sat Apr 18, 2020 11:41 am
Cheers Pete
Sounds like I could make it fit, I need the 3 yellows on the top 2 and 1 on the middle with the black and brown on the bottom
Don't know if they can be swapped around a bit.
If nothing else turns up I will take you up on that as your so far away, it's just so I can fit it to a combined reg/rect.
Tim
moizeau
#4 PostAuthor: moizeau » Sat Apr 18, 2020 12:26 pm
This is it Tim
tim.25
#5 PostAuthor: tim.25 » Sat Apr 18, 2020 12:44 pm
Ahh.
It has spade terminals and I have pins so probably won't work.
Thanks for your help anyway.
Tim
