Z900 Front Brake Pads - Advice wanted
#1 PostAuthor: Pigford » Fri May 01, 2020 3:18 pm
My front brake (single disc) is feckin' hopeless - even after fitting an expensive set from Brembo FFS :??
Yes I know they're never great, but I want opinions on best pads for braking efficiency (not wear) pleeze.
Ta very muchly!
Re: Z900 Front Brake Pads - Advice wanted
#2 PostAuthor: warren3200gt » Fri May 01, 2020 3:23 pm
Pretty much all much of a muchness Pigford. Best you can do is ensure the disc surface is perfectly flat and has no ridges by having them surface ground. I can lock the front wheel on my bike with standard master and caliper.
#3 PostAuthor: Pigford » Fri May 01, 2020 3:36 pm
warren3200gt wrote:Pretty much all much of a muchness Pigford. Best you can do is ensure the disc surface is perfectly flat and has no ridges by having them surface ground. I can lock the front wheel on my bike with standard master and caliper.
Disc is pretty damned good, new pads done +2000 miles and still not much bite :shock:
Put in new brake fluid and lever is nice & firm - have had better brakes on Zeds in past.
I do have all the kit to swap to a twin set-up, just need the splitter, may have to consider that option I suppose?
Andrew_s
#4 PostAuthor: Andrew_s » Fri May 01, 2020 3:50 pm
Mark,
Pull out the pads and check if they've glazed - if they are then rough them up and try bedding them in again.
Current Bikes:
2023 R1250 GSA
flateddie
#5 PostAuthor: flateddie » Fri May 01, 2020 6:07 pm
my 1000a1 has a zrx master cylinder and twin discs and I think it would be better to put your feet down sometimes :shock:
Chris71
#6 PostAuthor: Chris71 » Fri May 01, 2020 8:51 pm
Make sure the master cylinder is not a miss match, the twin disc and single disc are different sizes.... or check the piston on the caliper is free or the master cylinder needs a kit...
Or maybe a rubber brake pipe is expanding.
Lots of thing to check, but even a single disc should pull up pretty good.
Good luck Chris
