Does anyone know where I can get a replacement ignition key for my 1973 Z1?
I noted down the number as 759
Z1 ignition key 759
Re: Z1 ignition key 759
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Adrian,
Are you sure that is the number?
Key numbers on Z1 were 751-755 only.
If so it has a replacement lock fitted.
Regards
Steve
Regards
Steve
thanks Steve,
I can have no idea of its 40 + years in the states, that is the number I wrote down on delivery.
Many thanks
Many thanks
My missing key..
Yes I hot 2 keys 754 earlier this year, Dave Marsden told me they might be worth a couple quid, stuck them on ebay, a guy in Japan bought them for £50 , within 2 hours being on, so yes they are rare, 751 to 756.
David and that helps me because?
Adrian90s wrote:David and that helps me because?
Take it you’ve bought one then Adrian as he’s only 5 left
Yes, taken the plunge, at least its not a blank.
No reason, just a bit of info on keys.
