Lithium ion batteries
Zedorset
#1 PostAuthor: Zedorset » Fri May 15, 2020 8:10 pm
Hi all
I am thinking of putting a lithium ion battery on my Z1B, I am pissed off at buying new batteries every year as I am unable to get electrickery to run trickle charger in my garage, has anyone done this if so is there anything I need to do?
Jon
1975 Kawasaki Z1B
1979 Triumph Bonneville T140D
1969 BSA B25 Starfire
Re: Lithium ion batteries
#2 PostAuthor: chrisu » Sat May 16, 2020 6:05 am
Minimum have a modern solid state reg/rec on the bike.
#3 PostAuthor: Pigford » Sat May 16, 2020 7:05 am
They need to be charged at a higher rate than lead-acid/gel (so what Chris said).
I used on on my old Harris Z1000 and it was fine for 2 yrs use (the sold it :roll: )
Zedorset
#4 PostAuthor: Zedorset » Sat May 16, 2020 7:37 am
Thanks, I do have a modern reg/rec so looks to be a good way forward.
1975 Kawasaki Z1B
#5 PostAuthor: chrisu » Sat May 16, 2020 8:01 am
and a liFe specific charger to be safe.
rickm
#6 PostAuthor: rickm » Sat May 16, 2020 9:07 am
I've now got LiFe batteries on all 3 of my bikes, and don't regret it at all.
I know that there are a few cautionary things that need considering (charge rate, having a good reg/rectifier, etc). I may just be lucky, but I've not had a problem, even with 40 yr old electrics on the bikes.
Without stating the obvious, you just need to make sure you get a size that will fit your battery box. When I looked, a lot of them seem to be 5mm wider than the standard battery. You can usually make these fit, but just something to be aware of.
H2B GPZ900R
Users browsing this forum: No registered users and 77 guests
