Rear wheel bearing spacer
Stogmuller
#1 PostAuthor: Stogmuller » Fri May 15, 2020 11:07 pm
Trying to reassemble my rear wheel after fitting new bearings,,and the spacer which goes in between the bearings has gone awol,,! :o
Can anyone tell me measurements or better a pic and measurements,,,,pls
Bikes a 1976 Z900 with spoked wheels,,,?
CAT3
Re: Rear wheel bearing spacer
#2 PostAuthor: CAT3 » Sat May 16, 2020 3:00 pm
Unless someone has one lying around that they can measure the easiest thing to do would be to measure the wheel hub itself between the two bearing seating recesses with a vernier caliper, if you have one.
Sorry I'm not more help :)
wilsonsjw11
#3 PostAuthor: wilsonsjw11 » Sun May 17, 2020 7:35 pm
The spare rear drum spacer I have measures 65.05mm.
Regards
Steve
Stogmuller
#4 PostAuthor: Stogmuller » Mon May 18, 2020 10:59 pm
Thanks for help,, but I made a boo boo ,,not the inner spacer ,, it’s the outer shouldered one that I need ,, :(
Jumbo
#5 PostAuthor: Jumbo » Tue May 19, 2020 8:51 am
Not sure which side you need but they seem to be available from Z Power
http://www.z-power.co.uk/rear-wheel-sle ... -1972-1976
http://www.z-power.co.uk/rear-wheel-spa ... -1972-1976
The CMSL site does sell parts but is good for the drawings
https://www.cmsnl.com/kawasaki-kz900a4- ... sOctehKjIU
LE to JOG on a z900
P.U.M.
Stogmuller
#6 PostAuthor: Stogmuller » Tue May 19, 2020 9:26 am
Oh whoops,! Thanks for that,,I did look through the list at Zpower but couldn’t see it so assumed didn’t keep it,,
Guess I should have asked,
Cheers :D
