Nearly got the throttle body and injectors off (having hacksawed through the airbox rubbers) and I'm stuck on the most ridiculous thing. The TPS plug, I can see a small wire clip, similar to that on the injectors, but it doesn't seem to work in the same way. How the ***** does it come off? I thought a bank of carbs could be fun but this brings in another level, no bloody room at all.
DFI plug
Re: DFI plug
Sorted, it is the same kind as the injectors but just didn't want to play to start with.
