Hi All
Does anyone know what is an acceptable vertical (Up & down) movement for piston rings on standard ART pistons on Z1000 A1?
Also the vertical height of the slots?
David
Z1000 A1 - Piston ring float querie
David32knyte
- Regular Poster
Re: Z1000 A1 - Piston ring float querie
According to the genuine Kawasaki manual for the A1:
Top ring groove clearance 0.040 - 0.080 mm (service limit 0.15 mm)
2nd ring groove clearance 0.030 - 0.070 mm (service limit 0.15 mm)
Groove widths
Top 1.23 - 1.25 mm (service limit 1.33 mm)
2nd 1.22 - 1.24 mm (service limit 1.32 mm)
Oil 2.51 - 2.53 mm (service limit 2.60 mm)
Groove widths
David32knyte
- Regular Poster
[quote="TiBolts"]According to the genuine Kawasaki manual for the A1:
Groove widths
[/quote]
Thanks for the numbers.
Fingers crossed! (Certainly seemed more play than that when I wiggled it up and down)
Groove widths
