Wiring loom
Adrian90s
Wiring loom
#1 PostAuthor: Adrian90s » Fri Jun 05, 2020 10:44 am
the wiring on my bike is generally rough, the handlebar looms are both taped, did it come like that, it is neat.
Is it a straightforward job?
Its a usa bike and I've renewed the clock wiring, will that have different coloured wires to a new loom?
Re: Wiring loom
#2 PostAuthor: Philippe » Fri Jun 05, 2020 11:25 am
Hi Adrian
after 40 + years it's normal that wiring looms are a bit rough...mind that there is a difference between the wiring of the handlebar switches between the US and the European version. The US version has no little 4 watt bulb in the headlight and the right hand switch has only two light positions, "on" and "off".
You'll have to find out if your bike has a US or a Euro main loom and switches or a mix of both.
Use an electric wiring diagram to find it out.
Good luck and mind the gremlins !!!! They hide in the smallest wires of a loom and appear suddenly when you expect them the least.
wilsonsjw11
Re: Wiring loom
#3 PostAuthor: wilsonsjw11 » Fri Jun 05, 2020 7:20 pm
Buy a pattern wiring loom from Zpower,fit and forget.
Regards
Steve
Adrian90s
Re: Wiring loom
#4 PostAuthor: Adrian90s » Sat Jun 06, 2020 7:46 am
Thanks for the replies, the Z power one comes with 4 harnesses, is it easy to fit? Handlebar switch wires?
Adrian90s
Re: Wiring loom
#5 PostAuthor: Adrian90s » Sat Jun 06, 2020 7:48 am
Mine is usa version, will the zpower one go straight on?
rickm
Re: Wiring loom
#6 PostAuthor: rickm » Sat Jun 06, 2020 9:02 am
As Philippe says, there are a number of key differences in how the US bikes were wired up compared to Euro models. What bike is it?
I'm in a similar position with a US import J model. I want to simplify and renew the wiring, but haven't attempted a complete re-wire before and don't want to make a complete hash of doing it myself !
I'm sure you could make an off the shelf new loom fit, but but you will most likely need to adapt it quite a bit (unless it's specifically for a US model). In which case you might as well get a custom loom made in the first place?
H2B GPZ900R
Adrian90s
Re: Wiring loom
#7 PostAuthor: Adrian90s » Sat Jun 06, 2020 12:21 pm
Hi,
Its a Z1 1973, USA import , I've had the clocks done with wiring renewed from the clocks (extra wires for brake failure lamp ?)
Do I specifically ask for a usa wiring loom, I have ordered USA style handlebar switches with attached wiring harnesses
Adrian90s
Re: Wiring loom
#8 PostAuthor: Adrian90s » Sat Jun 06, 2020 12:22 pm
the h/bar switches/ harness are early Z1 style
rickm
Re: Wiring loom
#9 PostAuthor: rickm » Sat Jun 06, 2020 12:33 pm
May be best to ask Z-Power about this if you're looking at one of their looms ?
If you could get a US specific loom then I guess you're gonna be a lot closer to plug n play !
H2B GPZ900R
Re: Wiring loom
#10 PostAuthor: chrisu » Sat Jun 06, 2020 12:35 pm
i've got a 73 USA Z1 and the zpower loom fitted straight on.
Adrian90s
Re: Wiring loom
#11 PostAuthor: Adrian90s » Sat Jun 06, 2020 5:13 pm
Thanks Chrisu ,
Is it an easy and quick fit?
wilsonsjw11
Re: Wiring loom
#12 PostAuthor: wilsonsjw11 » Sat Jun 06, 2020 7:03 pm
If you have John Brookes excellent book it will show where on the frame to attach the cable ties too.
Regards
Steve
Re: Wiring loom
#13 PostAuthor: chrisu » Sun Jun 07, 2020 6:19 am
Adrian90s wrote:Thanks Chrisu ,
It was. I have no loom on the bike when I got it. Also Sven has just done this on his z1b.
Users browsing this forum: Maunders and 47 guests
