Micron fork brace
wayno
Micron fork brace
#1 PostAuthor: wayno » Fri Jun 19, 2020 2:22 pm
I have a micron brace that came in a box of other bits for a 900 A4 a while back, it has 81 86 stamped on the bridging part and 56g on the clamp sections, can anyone confirm that it's for the A4 or any other bikes?
Cheers Wayne
compo z1r
Re: Micron fork brace
#2 PostAuthor: compo z1r » Fri Jun 19, 2020 5:09 pm
Wayne I’ve just sent mike a brace a week or two back have u 187 mm give or take centre to centre at clamping that’s what a z1r was a st is 220 mm think a a4 would b same as z1r but has I’ve not had one don’t know ?
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
compo z1r
#3 PostAuthor: compo z1r » Fri Jun 19, 2020 5:10 pm
MikeP
#4 PostAuthor: MikeP » Fri Jun 19, 2020 5:54 pm
compo z1r wrote:8DA88204-87F0-4C2D-BEA9-BA09A35C21C5.jpeg
Hi Wayne and Neil, I haven't done anything with Neil's fork brace so can get you all the dimensions needed if required? Cheers, Mike
wayno
#5 PostAuthor: wayno » Fri Jun 19, 2020 6:27 pm
Thanks guys, center to centre is 180mm and the internals of the clamp is 51mm ish
Gus
#6 PostAuthor: Gus » Fri Jun 19, 2020 6:35 pm
56G for Z's
58G for GPZ/J/R
56mm is the diameter of the forks where the rubber shroud slides over the top of the fork leg. slide the shrouds up fit the fork brace then the rubbers slide on to the top of the brace.
Gus
"Set the GRINDER on it"
wayno
#7 PostAuthor: wayno » Fri Jun 19, 2020 6:58 pm
Thanks Gus, not looking to fit to mine, going to stick on eBay .
