Hi,
I’m putting my A1 back together but can’t find replacement generator cover insulation anywhere, you know, the foam that sits behind the cover... anyone know where I can get some or if there is an alternative?
Russ
Where to get or is there an alternative?
Z650C2, B1, F1, ZX9R, Z1000A1
Re: Where to get or is there an alternative?
Hi Russ
I don't know what you mean with "generator cover insulation". Do you mean " sprocket cover insulation " ?
If you mean that and you can't find it, never mind. Your bike will ride as good without it. Only anoraks like me care about it and make sure it's there.
Sorry, yes its the sprocket cover
Russ did u get this one then it was on eBay till 5 this morn
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
And if not I got this one from bike master in Germany
