Used 73 Z1 Ducktail
wilsonsjw11
Used 73 Z1 Ducktail
#1 PostAuthor: wilsonsjw11 » Thu Aug 13, 2020 2:57 pm
As the heading says, used 73 Z1 ducktail wanted please.Not Z1A or Z1B.
Regards.
Steve.
Re: 73 Z1 Ducktail
#2 PostAuthor: Philippe » Thu Aug 13, 2020 3:12 pm
wilsonsjw11
Re: 73 Z1 Ducktail
#3 PostAuthor: wilsonsjw11 » Thu Aug 13, 2020 3:53 pm
Philippe,
Thanks for the heads up but not with that graze and split on it.
Regards
Steve
A1John
Re: 73 Z1 Ducktail
#4 PostAuthor: A1John » Thu Aug 13, 2020 4:41 pm
wilsonsjw11
Re: 73 Z1 Ducktail
#5 PostAuthor: wilsonsjw11 » Thu Aug 13, 2020 4:54 pm
Thanks for the link but I'm after one that requires painting.
Regards
Steve.
Mick J
Re: Used 73 Z1 Ducktail
#6 PostAuthor: Mick J » Thu Aug 13, 2020 5:31 pm
How do you know which model of Z1 it is off? I thought they were all the same up to the squarer Z900 version, someone enlighten me please
73z1
#7 PostAuthor: 73z1 » Thu Aug 13, 2020 5:43 pm
73,74,75 are the same, 74,75 decals are hard to remove, it can be done.
wilsonsjw11
#8 PostAuthor: wilsonsjw11 » Thu Aug 13, 2020 8:23 pm
73,74 and 75 are not the same.
There is a very small difference on the 73 unit hence me being specific.
Regards
Steve
#9 PostAuthor: Philippe » Fri Aug 14, 2020 3:09 am
Hi Steve
tell us all about the little difference, I'm curious and always ready to know more about the Z1.
wilsonsjw11
#10 PostAuthor: wilsonsjw11 » Fri Aug 14, 2020 6:24 am
Philippe,
If you remove the document tray on a Z1 you will see 2 "rails" in the plastic moulding of the tail.Not on Z1A or Z1B or the later NOS units either.
Regards
Steve
hutch
#11 PostAuthor: hutch » Fri Aug 14, 2020 8:36 am
True, they are not the same.
#12 PostAuthor: Philippe » Fri Aug 14, 2020 11:08 am
Hi Steve
thanks for the information, I'll check it out !
