Z900 Wheel Hub
RALPHARAMA
Z900 Wheel Hub
#1 PostAuthor: RALPHARAMA » Fri Aug 21, 2020 4:19 pm
Looking for a rear wheel hub for my Z900. Don't need rim or spokes. I do need the sprocket carrier, brake etc.
Dosh waiting :D
Ralph Ferrand
8 Valve Mark
Re: Z900 Wheel Hub
#2 PostAuthor: 8 Valve Mark » Sat Aug 22, 2020 12:15 am
triggers' broom springs to mind Ralph! :lol. however; I've got a spare z1/9 sprocket carrier, with a good sprocket attached via good studs, nuts n shims so good to go n cush rubbers if required .I've got a couple of brake plates too z1a-b, n z900 they're both very different, z9 with the raised lettering on the brake drum is a bit scarce but I think I have both options,.m.
