Currently restoring this '72 Z1 and fitting a new front brake light switch.
Question is, do you need to apply any sealant to the threads to prevent it leaking or just screw it in tight?
Front Brake Light Switch
Re: Front Brake Light Switch
Hi Andrew
nice project! Keep the pictures coming please.
The front brake light switch doesn't need a sealant. Use a 26 mm wrench and torque it between 2.6 and 3 Kg/m.
Good luck with the restoration!
Users browsing this forum: No registered users and 200 guests
